Is the ok to do?
Discussion in 'Archived Threads 2001-2004' started by Scott Burke, Mar 27, 2002.
  1. Scott Burke
    Scott Burke Second Unit
    Nov 27, 2000
    479
    31
    United States
    Scott B.
    I have a Denon 1800 with 4 8ohm speakers. What I want to do is put on a 6ohm speaker. Is this ok to do? Can you have two different impedence speakers running at the same time? I tried it out and it seems to be ok, but I'm using the lower impedence speaker as my center channel and I am noticing that dialog is hardly audible. Does this have anything to do with impedence? I have already matched levels using VE and an SPL meter. Just curious. Thanks
  2. Scott Burke
    Nov 27, 2000
    479
    31
    United States
    Scott B.
    Anybody have any thoughts?
  3. Chris_Freeman
    Mar 15, 2002
    25
    As long as the receiver can handle a 6ohm load, most can go down to 4, its not going to hurt anything. With the levels matched you shouldnt be able to tell the difference unless you are a very picky listener.
  4. Scott Burke
    Nov 27, 2000
    479
    31
    United States
    Scott B.
    thanks for the response
