Is the Denon 3802 suitable for bi-wiring my speakers?
Discussion in 'Archived Threads 2001-2004' started by Antonio, Apr 13, 2002.
  1. Antonio
    Antonio Extra
    Mar 16, 2002
    22
    I have read that bi-wiring only makes sense if both the speakers and amplifier has two sets of terminals (or posts) per channel. I have Paradigm Studio 60s and a Denon 3802. While the Paradigm Studio 60s have two sets of posts in the back for bi-wiring, the Denon does not and I was wondering if it is worthwhile to still try bi-wiring my speakers. I suppose the wiring would be a bit funny though...
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    You do not need two sets of speaker outputs to bi-wire. Simply run two sets of wire from each L-R and you're set. Some people use the B speaker outputs on A/B equipped receivers to achieve the same purpose but I feel this limits the future front stage options and is unnecessary.
  3. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    Use banana plugs in the ends of the receiver's speaker terminals and then use bare wire in the little notch at the 2 o'clock position of the same terminals.
