Is the AVIA DVD still the best for calibrating your audio/video system?
Discussion in 'Archived Threads 2001-2004' started by Manuel Parrado, Apr 6, 2002.
  1. Manuel Parrado
    Manuel Parrado Stunt Coordinator
    Jan 7, 2001
    119
    Just that question.
  2. Steve WC
    Steve WC Stunt Coordinator
    Dec 15, 2001
    180
    I am a total HT beginner so I bought the Sound and Vision calibration disc. It was very easy to use. It took less than 1hr. to calibrate both audio and video. Plus, it only cost $15.00.
  3. Manuel Parrado
    Jan 7, 2001
    119
    I guess I'll have to look into that one.
    Thanks.
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    The Sound & Vision disc is sort of the 2nd rev of the Avia disc. (Avia is strictly 5.1 but S&V includes 6.1.)
    But Avia has more tests.
    But I also seem to remember someone saying that if you calibrate your video to Avia, it comes out with a yellowish tinge.
    I have used both, and to be honest, I prefer S&V: because it's "simpler" ! [​IMG]
    Cheaper too. I've found it at Frys for $15.
  5. Manuel Parrado
    Jan 7, 2001
    119
    I did not know about this Sound and Vision.
    I fell behind last year when the only alternatives where the Avia and the HT Essentials discs.
    I will certainly consider this other disc (even more if it is cheaper).
    Thanks.
  6. SteveA
    SteveA Supporting Actor
    May 25, 2000
    700
    I've used Avia on a couple of sets now and never seen any kind of a yellowish tinge afterward. Avia is the yardstick that all other calibration discs are measured against.
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    After doing the contrast test with any test disk, you should lower the contrast significantly from the suggested value and then complete the calibration, if you want the longest life from your TV.
    A general rule is contrast no more than 1/3 for projection TV or no more than 1/2 for direct view TV.
    If you have viewed uncalibrated TV sets for a long time, it will take time getting used to the picture from a properly calibrated TV.
    Source material may vary in color content. Even an aging lamp in a telecine machine when a movie is committed to video during DVD production may result in a yellowish tinge for that movie.
    Video hints:
  8. John Cain
    John Cain Second Unit
    Nov 19, 2000
    359
    Yes it is....
  9. Dave H
    Dave H Producer
    Aug 13, 2000
    5,578
    207
    9,110
    Avia is the best.
  10. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    I agree with the other "yes" replies. The older Video Essentials was harder to use and out of date, and is no longer in production. There is a newer one, Digital Video Essentials, that is in development, but I have no idea if it will be as good as Avia.
  11. Matt Butler
    Matt Butler Screenwriter
    Jun 23, 2001
    1,915
    2
    Ive been using the old Video Essentials. Should I get a different one?
  12. Kevin C Brown
    Aug 3, 2000
    5,712
    A lot of the video tests on the S&V disc *are* the original Avia tests.
    Same people did both discs. (With David Ranada.)
  13. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    you could always try winning one here
  14. Aaron Garman
    Aaron Garman Second Unit
    Oct 23, 2001
    382
    Hello all. I've used video essentials for over 3 years, and tons of TV's. I used to use it on the TV's at Best Buy when I worked there. Overall, I have gotten terrific results on NTSC and HDTV. Hopefully this rumoured Digital Video Essentials will carry on the tradition.
    AJ Garman
