Is the 5 ch driven output gap narrowing between HK and others?
Discussion in 'AV Receivers' started by Shiu, Aug 29, 2004.
  1. Shiu
    Shiu Second Unit
    Feb 18, 2003
    447
    http://www.soundandvisionmag.com/ass...verlab0804.pdf
    In the current S&V issue, the JVC, Yamaha, and the often bashed Sony (a DE model) entry level receivers all tested with reasonable 5 channel driven outputs. Among the 3, the Sony appears to have the best results in output at 4 ohms and its list price is the lowest.
    It may be time these receivers can be compared to HKAVR130/230 etc., in terms of output power.
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    In terms of output, maybe. But in terms of honesty, not quite yet. With 5 channels driven at 8 ohms, the Sony was measured at 76% of it's advertised output. The Yamaha 61% and the JVC only 48%. H/K regularly exceeds it's advertised output (100%+). Sure, all three will put out a few more watts than the H/K 130/230, but looking at the advertised power they should be 2-3 times more powerful. But it doesn't really matter as all three would be perfectly fine 90% of the time for 90% of those who bought them. Numbers are numbers and specs are specs. What really matters is how you feel after you turn the large knob on the front panel to the right [​IMG] .
  3. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Is wattage all that really matters? I have a feeling an Arcam A65+ which is 40 watts per channel will sonically eclipse all of those receivers.
  4. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Not really. I'd still prefer the Yamaha RX-V750 reviewed over the Sony DE-895.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    TRUE wattage, not just wattage, and current is also a small detail. The ability to deliver plenty of current means an amp can deliver more than it's rated power without choking. The A65+ is an integrated and does not include any processing or video, so it is less complicated and focuses on the things it is meant to do, not to mention it is 2ch only. Arcam is not building these integrateds to compete with the $300 receiver market either (my friend's A80 cost almost as much as my Marantz 8300). I would take the A65 over most receivers in it's price range [​IMG] There are tube amps that deliver only 8wpc that will likely perform as well as the A65+.
    My Marantz PM7000 is rated at 95x2, but a review showed it to actually deliver 115wpc.
  6. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    Yes, Marantz also seems to give accurate power ratings. In the 1/04 issue of S/V, the SR5400, rated at 90 X 6 showed to give 103 X 5. Close enough to me [​IMG] .
  7. Charlie C
    Charlie C Stunt Coordinator
    Jun 25, 2004
    237
    "Is wattage all that really matters?"
    shiat! lets not go here again! [​IMG]
