Is Strangers on a Train DVD OAR?
Discussion in 'Archived Threads 2001-2004' started by Ernest Aguayo, Dec 2, 2001.
  1. Ernest Aguayo
    Ernest Aguayo Stunt Coordinator
    Apr 5, 2000
    105
    I think I remember seeing a thread about this, but I cannot find it again when I search for it:
    Does the Strangers on a Train DVD say it's "modified to fit your screen" when it's actually presented in OAR?
    Thanks for any clarification.
  2. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    Both the American and British versions on my copy are preceded by the "...formatted to fit your screen..." message. As far as I know, 1.37:1 is its original aspect ratio.
  3. Mitchell Kaufman
    Mar 17, 2001
    41
    Yes, it's an Academy Ratio film (1.37:1). The only way in which it's "modified" is the difference between 1.33:1 and 1.37:1, which is minimal (and true of most such transfers anyway).
    Some early DVD's were mislabelled in this way; it seemed that they thought anything that wasn't widescreen was of necessity cropped.
    What annoys me more is the way in which so many 1.85:1 films are cropped to fit the standard widescreen display ratio of 1.78:1. Information is frequently lost on the left and/or right.
    MK
  4. Ernest Aguayo
    Apr 5, 2000
    105
    Cool. Thanks for the info.
  5. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,563
    195
    9,110
    Georgia (the state)
    Patrick McCart
    1.37:1 is silent apature.
    Also, most 1.78:1 DVD's of 1.85:1 films don't lose side info. They're just matted to 1.78:1 instead of 1.85:1 You actually gain a ribbon of picture.
