mike carlton
- Mar 13, 2020
- mike
I close on my new home next week and it has Sonos in the living room and theater room. I plan on adding to the system and wanted to know if it's worth it to stay with
Sonos is also limited to Dolby Digital and does not support DTS.Sonos is well worth the money for whole home audio but needs a strong and fast network to operate properly. The Sonos Playbar sounds OK but only supports optical, no HDMI. This means that you are limited on surround modes because the Playbar cannot receive or decode any of the newer high def surround modes.
I personally wouldn't use any soundbar in a theater room. I would rather spend the money on a decent receiver and speakers. You could use what is there for now but run speaker wires when you are finishing the room for future expansion.
Congratulations on the new house!
Brian
Which was the point of my previous comment.Sonos is also limited to Dolby Digital and does not support DTS.
