The signal-to-noise ratio is important on any hi-fi component. Fortunately, it is a spec that CD players have always excelled at. As a reference, a cassette deck without Dolby NR has a relatively low (and noisy) S/N ratio of about 55dB. With Dolby B and C, typical figures are 65 and 75dB respectively. By comparison, most budget CD players easily achieve S/N ratios of 95dB or better.
In short, S/N ratio is important, but virtually a non-issue for CD players.
Wayne A. Pflughaupt
------------------ My Equipment List
S/N or SNR is a measure of the analog outputs; dynamic range is another. If you use the CD player as a transport, the SNR is not important.
------------------ equipment list
