Is pushing a BFD to clip OK sometimes?
Discussion in 'Speakers & Subwoofers' started by Dan_M, Jul 24, 2004.
  1. Dan_M
    Dan_M Agent
    Jun 10, 2004
    40
    I built my own 142l sub and have a pretty nice room curve dialed in. Ever since adding the BFD I noticed my sub tends to bottom out more than before. I assume this is because I tamed a +12db hump from 50-60hz, so when calibrated with my mains the sub is producing more sub 50hz material than before. The LFE line level is setup so I only get very brief glimpses of the red led on the BFD when playing bass heavy material like U571 and Fight Club (Psycho Boy and Operation Latte).
    I was wondering that since the BFD soft clips I could raise the line level so that instead of the driver bottoming out the BFD clips and the driver gets no signal.
  2. Dan_M
    Dan_M Agent
    Jun 10, 2004
    40
    After dorking around with LFE levels more I figured out that much of what I was hearing was actually the BFD clipping already. I lowered the line levels and turned up the amp a bit and things cleaned up nicely.
    Are there any disadvantages in running a lower signal to the BFD? I read that this may cause it to not process the signal properly on lower volume bass.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Sure, it’s not a good idea to feed the BFD a low-level signal. But in your situation, where it’s clipping, it’s no problem to just turn it down a little.
    Wayne A. Pflughaupt
