Is PE 250w plate amp for real?
Discussion in 'Archived Threads 2001-2004' started by AlexKunec, Mar 29, 2002.
  1. AlexKunec
    AlexKunec Stunt Coordinator
    Mar 9, 2002
    161
    I just bought a 250w parts express plate amp (300-793) and plan to match it with a adire shiva driver.
    The driver hasn't come in yet, so I hooked it up to my friends pioneer diamondplated car sub (200w Max 4ohm). It didn't go very loud at all. My receiver was at +6db for subout It was 3/4 cranked and it wasn't even that loud. Would it be any louder with a shiva hooked up?
    I hooked it back up to my friends 180w car amp and it was so much louder.
    Does anyone have good experiences with this amp?
  2. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I run a SVS 25-31 in a medium sized room, I have my pre/pro at -10 and the plate amp is about 1/2 way turned up. Works for me
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    I have a Tempest in a 260L enclosure tuned to 16hz with a 6" port using the Adire equivalent to that amp. I have it set at about 7/10 of full. Then on my Onkyo receiver I have the sub output 18dB below the mains (sub -10, mains at +8) and the sub is still running a few dB hot.
  4. Mike Dr
    Mike Dr Stunt Coordinator
    Jul 30, 2000
    171
    Alex, dont forget that when you're testing you're testing in your house right? the acoustics of a car and a room are quite different.. anything will sound louder in a confined space like a car..
  5. Rudy H
    Rudy H Stunt Coordinator
    Mar 2, 2002
    105
    With my PE 250watt plate amp and my 15inch Dayton DVC in 5.3cf sealed in my HT, I crack 120db @ 45hz [​IMG]
    With my Kicker Impulse 352xi (75x1) and my 10inch Orion XTR in my car, I only get 118db @ 45hz [​IMG]
  6. AlexKunec
    Mar 9, 2002
    161
    Could it be that the bass boost on the plate amp is currently disabled. I just heard my brothers home subwoofer in my home, and it puts out twice as much as mine. His is only rated at 150W.
