Is only a stereo reciever needed for two speakers?
Discussion in 'AV Receivers' started by Seam Dempsy, Jan 28, 2004.
  1. Seam Dempsy
    Seam Dempsy Stunt Coordinator
    Dec 2, 2003
    75
    Im still in highschool and have a small room. Both make a full quality home thater system a ridiculous thing to have at this time. But I do want better speakers than the 10W on my TV. My question then is: can I get away with only a stereo reciever if I have only two tower speakers?
  2. DaveDickey
    DaveDickey Stunt Coordinator
    Aug 18, 2003
    235
    Yes. If you want stereo sound, you'll need only two speakers, and a stereo receiver is what you're looking for.
  3. Seam Dempsy
    Dec 2, 2003
    75
    Thanks for the assurance![​IMG]
  4. Seam Dempsy
    Dec 2, 2003
    75
    A question on stero reicevers.
    How do in I play my DVD's through them if they do not have any video input or outputs? Du I connect only the audio section of the cables to the reciever and then the video to the TV? Thanks.
  5. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    Thats exactly what you do since you have no other choice. :-D
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    If your TV has enough inputs, then you never need to involve a receiver for video.
    Another alternative, though a little more expensive, is an integrated amplifier. You give up some features (tuner, DSP, etc...) but generally get a higher quality amp.
  7. zangler
    zangler Extra
    Apr 16, 2003
    21
    depending on how much you want to spend, you could get a 5 or 7 channel receiver and then 'grow' into it...you dont have to have all the speakers at once.
  8. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Honestly, you'll get better sound out of a stereo receiver compared to a similarly priced multichannel unit. If you can afford a decent multi-channel receiver though, you will have gone a long way towards your next step already. What's the budget?
  9. Rich Malloy
    Rich Malloy Producer
    Apr 9, 2000
    3,998
    Yeah, if this is for music mostly, and TV and movies secondarily, then the sound quality of the two-channel model will almost invariably trounce a home theater receiver costing the same or even a good deal more.
    It's just so easy to make a pure analog, two-channel receiver/integrated that truly sings. Conversely, not many "home theater" receivers can play anything that sounds even remotely like music.
    If you're looking for under-$500 receivers/integrateds, Art Dudley reviewed a couple of $399 models from NAD and Rotel that might give you an idea what to look/listen for. Those reviews start here: http://www.stereophile.com//amplific...85/index1.html
  10. Seam Dempsy
    Dec 2, 2003
    75
    Well I want a full set of JBL speakers but this summer I have to start saving up for my month long excursion to Europe in June 2005. I wont be able to get all the speakers before then and will not be able to start getting them after the intial two for a year. So, I only need a cheap stereo reciever that needs to only last me a year to service the first two speakers I will be getting. Come 2005 I will toss the old reciever and then purchase a high-quality multi-channel to service the entire set I will then begin purchasing.
