Is my Shack SPL meter defective?
Discussion in 'Speakers & Subwoofers' started by RichardJ, Jul 30, 2003.
  1. RichardJ
    RichardJ Stunt Coordinator
    Mar 30, 2003
    57
    Hey -
    I just bought my first SPL meter, the analog model from Radio Shack. I am trying to equalize the volume settings on my speakers by using the Yamaha test tones, which are a pink noise static (sounds like a radio with no signal). However, while the BATT TEST mode shows a signal, and sometimes the needle bounces when changing the range, I am not getting a reading at all! At 60, 70, or 80 db the needle stays at -10db, even when I crank the volume to an almost painful level. I have the meter set a mode C and slow weighting, though changing those settings seems to do nothing.
    Does anyone have advice on how to get this thing to work, or is it probably just defective?
    Thanks!
    Richard
  2. Kevinkall
    Kevinkall Second Unit
    Mar 20, 2003
    331
    Sounds like it may be broke. I have the Radio Shack Digital SPL meter and love it!
  3. Josh~H
    Josh~H Stunt Coordinator
    Jul 21, 2003
    126
    There's definitely something wrong with it. At comfortable listening levels, the test tone will probably be in the 60-70 dB range. I just bought the analog model at Radioshack this past weekend, and it works great.
  4. Rajeev_s
    Rajeev_s Stunt Coordinator
    Dec 20, 2002
    184
    I bought analog SPL meter at RS for $25, it works just fine. Calibration was smooth. May be yours is defective, RS will exchange it, I think their return policy is good.
  5. Rus Bowisc
    Rus Bowisc Stunt Coordinator
    Jul 18, 2003
    50
    Quick question... I apologize for going OT...
    Are "compensation" settings the same for both the analog and digital RS meter?
    Rus
  6. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    i had the same thing happen on the first SPL meter i bought from radio shack. they had no problem switching it with a new one when i went back to the store.
  7. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
