Is my Radio Shack sound meter working properly?
Discussion in 'Archived Threads 2001-2004' started by Ben Jordan, Oct 7, 2002.
  1. Ben Jordan
    Ben Jordan Stunt Coordinator
    Jul 4, 2002
    94
    GSP
    Ben
    I ask because I was watching Fight Club the other night with my Onkyo 787 set to a reference of 75dB (-10dB on dial), and my 22-31PCi at +3dB...
    ...and the plane crash hit 112dB (110dB setting, c weighting, fast response), and the car crash hit 114dB.
    My understanding is that the true dB's are even higher, since the radio shack meter isn't as sensitive with those low frequencies.
    I didn't even try it at full 85dB, because I didn't want to disturb my neighbors too much, since it was almost 9PM.
    I'm holding the meter an arms length away from me, landing right in my viewing spot, pointing toward the ceiling.
    Do these readings sound right? Should I be getting higher dBs? Lower?
    thanks
  2. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    What did you calibrate with? (What DVD, method, etc.)
  3. Ben Jordan
    Jul 4, 2002
    94
    GSP
    Ben
    Calibrated with Avia to be 85dB at the 0 point on my dial. Thanks.
  4. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    Keep in mind that the compensation figures for the RS meter are frequency specific and are intended to be used with sinusoidal test tones.
    When you use the meter with program material the meter is responding to all the sound, at all frequencies, from all speakers and not the subwoofer alone.
    All that being said, your SPL figures appear to be on the high side.
  5. Doug BW
    Doug BW Stunt Coordinator
    Nov 27, 2001
    141
    Have you EQed? People can have peaks in their bass response that are upwards of 10dB above the calibrated level.
  6. RichardH
    Nov 28, 2000
    742
    Good point, Doug. A big room node could be causing the spike on your meter. Do you have 5 speakers set to small? If so, try your test again, but this time, turn the sub off. Don't change any of the receiver settings, just leave the sub off. Then you can see what your main speakers are peaking at during those scenes.
  7. Phil_DC
    Phil_DC Stunt Coordinator
    Jul 20, 2002
    178
    Hey Ben,
    Whats the part number for that meter? I tried to get one a RadioShack the other day and they had no clue as to what I was taking about.
  8. Doug BW
    Nov 27, 2001
    141
    Phil, the catalog number for the RadioShack SPL meter is 33-2050. Full information maybe found at RadioShack's website, here.
  9. Phil_DC
    Jul 20, 2002
    178
    Thanks Doug!
  10. Ben Jordan
    Jul 4, 2002
    94
    GSP
    Ben
    Doug,
    I don't have any EQ hardware yet, but am very interested in getting something soon. Recommend anything for beginners? Wouldn't want to pay much more than say $300, if that's possible.
    Richard,
    Yes, all set to small. I will try that test again tonight hopefully, exact same settings, except with the sub off, and see what kind of dB's I get, and let you know. Should I perhaps run the test again, with all speakers unplugged, except the sub, and see what it is producing also?
    Thanks guys! Really appreciate your time.
  11. Doug BW
    Nov 27, 2001
    141
    Probably the two most popular/inexpensive boxes that people use to EQ their subs are the BFD (Behringer Feedback Destroyer) and the ART 351.
    I have the BFD, which you can get for around $125 delivered on the web. It's a parametric equalizer. It's fairly easy to use, though the ART, being a graphic equalizer, is probably a little more intuitive to use....though you trade off flexibility.
  12. Ben Jordan
    Jul 4, 2002
    94
    GSP
    Ben
    Thanks Doug. I'll pick up a BFD in the next couple of weeks then! Would I need anything else to go with it?
  13. RichardH
    Nov 28, 2000
    742
    I don't think it would cause any harm, but it might not be the best idea to run your reciever w/o any speakers. I think doing the "no sub" test should be sufficient to see what's going on.
  14. Doug BW
    Nov 27, 2001
    141
    You'll need one additional audio interconnect, an SPL meter (which you already have), and a CD with test tones. Good test tone CDs include the "BassZone Test CD" from www.stryke.com (that has sine waves at 1/6 octave intervals), and "CD 101" from www.autosound2000.com (that has sine waves at 1 hz intervals). Some people have made their own CDs.
    It's also helpful to have a tripod for the SPL meter. And some software to draw pretty graphs of your frequency response. And a spouse who can say with straight face, "Oh yes, that sounds much better now".
  15. Ben Jordan
    Jul 4, 2002
    94
    GSP
    Ben
    Doug,
    Thanks for the info. I was hoping to make my own test tones with the NCH Tone Generator (http://www.nch.com.au/tonegen/), which seems to be able to create some accurate WAV's I could burn. I have a tripod, and a very HT supportive fiance (getting married this Saturday!) who is more than happy to help out. [​IMG]
    Richard,
    I just finished the test with the SVS turned off via its amp switch, and here are my results:
    The airplane crash hit 102dB's at the maximum loud part, with most of it around 98dB's. The car crash hit a maximum of 100dB's, with most of it around 95-96dB's or so. All the same exact settings except for the meter which I put on 100dB and 90dB (ran test twice), instead of 110dB, to get a more accurate reading.
    Do these readings seem correct? I'll run Avia again tonight to verify my levels of 85dB at 0, and 75dB at -10.
    thanks!
  16. RichardH
    Nov 28, 2000
    742
    Was your volume knob at -10 like before? If so, I'd say those reading are normal. Full reference level means up to 105 dB peaks at the seats from any 1 channel. So, if you have a few of them going at the same time, it could be a little more. So, if you are running at 10 dB below reference, and a few channels go "full scale", then I think it's reasonable to have 102dB peaks at the seat.
    Truth be told, full reference is pretty dang loud. I think 10dB below w/ the subs a few dB hot is just right for a lot of people and still too loud for some (read: most women).
  17. Ben Jordan
    Jul 4, 2002
    94
    GSP
    Ben
    Yeah, same -10 as before, Richard.
    I agree on the loudness. Although I do love to turn it up to full reference or even a little higher to show off to my friends, if you know what I mean. [​IMG]
    And yes, -10 seems really good for me and my fiance for most movies, if not even a little lower. Gives enough to have a nice full sound, and great effects when they come along.
    Thanks again for your time!
  18. RichardH
    Nov 28, 2000
    742
    Sweet, glad it worked out for you!! And a fiance who's supportive of your hobby? Man, make sure to hold onto that one! [​IMG]
