Is Madisound Swan 305 rated at 8ohm or 4ohm?
Discussion in 'Archived Threads 2001-2004' started by Stephen Hopkins, Aug 28, 2002.
  1. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Is the Madisound Swan 305 rated at 8ohm of 4ohm? I can't find the info anywhere.
    I'm looking at building a 5.75 cu ft enclosure.
    Also, are there any drivers that can keep up with the Swan for less $$$? There's a guy selling a kicker solobaric 10" in the for sale forum for $40 that would roll off at under 22hz +_ 3db, but is 2db less loud than the swan... i'm only going to be using a 100w at 8ohm / 150w at 4ohm plate amp, so i'm guessing i need as much sensitivity as possible to get up around ref levels?
    thanks.
  2. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Depends on where you measure it due to its high inductance, if it's still the same driver I bought. I used 6ohms for calcs.
    None that I can think of. It's been ~the same price for 17-18yrs now IIRC, so it's really quite a bit cheaper than when it first came out.
    Yep.
    GM
  3. KrisPfeiffer
    KrisPfeiffer Extra
    Jun 3, 2002
    23
    Send them an email - they'll get back to you very quickly. Madisound is top-notch.
