NathanP
- Aug 13, 2001
Hi,
I'm using simple Radio Shack brand 18 gauge speaker wire on my home theater..
Is it worth upgrading to something bigger and better, say Monster Cable?
What gauge do you guys suggest?
I'm currently running a pro-logic setup with 2 subwoofers if that info would help...
Maybe a better "bassey" sound would be good, but I just want to make sure all the distortion and "ach" in the sound are cleared up...
Any other brands suggested?
I can probably get em' really cheap on Ebay..
Nathan
[Edited last by NathanP on August 27, 2001 at 10:35 PM]
Nathan
