Aslam Imran
- Mar 1, 2002
the title says it all
How do you know what bright is? One person may feel one component is bright while another may not. It's whether or not YOU like what you hear.
You mean when I am comparing two amps can I tell which is bright? In that case I can. Also I dont mean bright in a derogatory sense. All I am asking is does better imaging come with a pronounced upper end (given similar amps of similar build quality).
Assuming amplifiers that are performing properly ie. no excessive channel bleed/crosstalk, soundstage and imaging is mainly a function of speakers and the room.
Then why do reviewers characterize amps as having open soundstage and rock solid imaging, etc?
because as Obi mentioned, a warmer sound usually involves a roll-off of HF info
It's just as likely that a brighter sound is caused by a slightly accentuated treble, which is something that can be found on several speakers.
It's all relative - a neutral component will sound warm when compared to one with an up-tilted treble curve. And vice versa.
Or are they reserved for the high end because I have heard some fully balanced Krells that have both properties but no amp in the mid fi arena (Rotel, B&K, ATI, Parasound or Adcom) that could throw a wide and deep soundstage with precise placement of vocals and instruments.
In general, the better the electronics, the better the soundstage and imaging. IMO, no mid-fi components (Rotel, B&K, etc.) can produce anything even close to that which can be achieved with products from manufacturers such as Naim, Linn, Levinson, Lamm, etc.
Larry
In general, the better the electronics, the better the soundstage and imaging. IMO, no mid-fi components (Rotel, B&K, etc.) can produce anything even close to that which can be achieved with products from manufacturers such as Naim, Linn, Levinson, Lamm,, etc.
Wow, that's an extraordinary claim! I think you should try doing a level-matched DBT test with good solid-state power amps from "mid-fi" manufacturers and the high-end ones. You may be in for a big surprise. I think you will be amazed that mid-fi CD players, like the Meridian's or the Arcam's, or some of the Sony ES's, can easily match the expensive 2-box sets in DBT's, too. (That's one of the reasons why high-enders hate DBT's.)
There was a pretty well-known case of a high-end audio salesman not being able to tell the difference between a $500 Yamaha integrated amp and a Nelson Pass $$$ power amp in a DBT. Not all power amps sound alike, but the good ones are very similar.
Seriously, I think imaging and soundstage is about 95% speakers and room acoustics. The rest is basic audio engneering on the electronics to make sure they do not screw things up. Not really hard to do, but then no guarantee that they will be done correctly.
It's a great topic for discussion, Aslam, since we are all coming from different places due to our personal preferences and experiences with different equipment.
I actually was listening to some music score last night on my Denon 3801 and Infinitys and noticed that I could clearly place stringed instruments and piano notes in the sound field while I couldnt really place the drums exactly. I changed over to some other music scores and noticed the same thing. So I extrapolated and thought that if image specificity is an attribute of upper frequencies then brighter sounding amps with their pronounced treble should image better then warmer rolled off HF amps. But this is only a guess as I am beginning to find out from all of you.
In the interests of peace, I withdraw my statement and hereby state for the record that (1) all SONY products are every bit as good as higher-end products, and (2) any perceived differences between, for example, a SONY CD player and a Levinson reference player, are imaginary, and due entirely to pre-conceived notions.
See you all later.
Larry
Couldn't find difference between a Pass amp and a yamaha integrated in a DBT? Wow that is infact mind blowing.
