Is it possible to use a Palm Pilot as a Universal Remote?
Discussion in 'Archived Threads 2001-2004' started by Ryan Cruz, Apr 16, 2002.
  1. Ryan Cruz
    Ryan Cruz Stunt Coordinator
    Apr 2, 2002
    139
    Is there any good software you guys know that can transform my Palm into an all-in-one remote?
  2. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Ryan,
    Do a search on pda remote. There was a thread fairly recently on this by Patrick Sun I think. If i remember correctly, it worked but had a short range.
    Bill
  3. RandyRush
    RandyRush Stunt Coordinator
    Dec 11, 2001
    61
    I looked into doing this until I found out the range is mostly in the 6-8' range without an ugly extender. So I got the ProntoPro instead.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yes, it will work, but from everything i've heard, the strength of the IR repeater on the palm is not very good. so, you'll have to be very close to the component for it to work properly.
  5. BruZZi
    BruZZi Second Unit
    Nov 1, 1999
    327
  6. Ryan Cruz
    Apr 2, 2002
    139
    Thanks guys [​IMG]
