Is it possible to power 4-5 pairs of in-wall speakers off one 2-channel amp?
Discussion in 'Speakers' started by KyleT, Jul 11, 2003.
  1. KyleT
    KyleT Stunt Coordinator
    Nov 8, 2002
    59
    I was just wondering if this is possible and/or a recommended way of doing 'whole-house' audio?
    I'm planning on buying a pretty powerful amp for my home theater room, and it'd be pretty nice to be able to use the same amp for my in-wall stuff. As a rule of thumb, I probably wouldn't ever use the inwall system at the same time as the home theater system.
    The only problem I can see is somehow getting all 4-5 pairs, if they were on at the same time, to not load up my amp any more than 3-4 ohms.
  2. Chris Quinn
    Chris Quinn Screenwriter
    Jan 12, 2003
    1,127
    Google Niles Audio speaker selectors. I don't know anything about them but it may be what you need.
  3. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    Five sets of eight-ohm speakers in parallel will put you at 1.6 ohms --way beyond (below, in literal terms) the impedance receivers will tolerate. You will need to use a speaker switcher/selector that will control the minimum impedance seen by the receiver.
    This is a "possible" way of doing "whole house" audio. Another way is to wire them in series/parallel combinations to yield the right total impedance. The "recommended" way is to dedicate separate amps for each stereo pair or use one of the multi-amp, multi-zone "whole house" systems from Rotel, Crestron, Niles, etc.
