Is it possible to bypass the internal sub's amp?
Discussion in 'Archived Threads 2001-2004' started by Eduardo Martinez, Sep 7, 2001.
  1. Eduardo Martinez
    Jun 28, 1999
    18
    Can I connect a power amplifier to a powered sub? If the internal amplifier is damaged can I bypass it and use another amp? If yes, how?
    Eduardo
  2. John H
    John H Second Unit
    Nov 27, 1998
    472
    I have done this in the past. My subwoofer came equipped with speaker level input and output binding posts.
    I removed the AC unplugged amp from the cabinet. I then removed the wires to 1 pair of binding posts and attached the wires from the driver to the now unused posts.
    This made a convenient connection for external amplification.
    Make sure your amplifier selection is appropriate. Some manufactures use built in subsonic filters as well as low end EQ boost.
    I am not an expert on this. I'm sure others will reply.
    Bedroom Based Theater
    Looking through a glass onion
    [Edited last by John H on September 07, 2001 at 02:36 PM]
