Is it ok to mix connection wire brands? In this case bluejean with bettercables?
Discussion in 'Accessories, Cables, and Remotes' started by Todd smith, Sep 13, 2004.
  1. Todd smith
    Todd smith Supporting Actor
    Apr 2, 2002
    643
    Probably a stupid question, but can I safely mix different brands of connection wires? I want to buy bluejean component cable and bettercables rca cables for dvd-A and sacd. Any problem or performance issues with doing this or do I need to go with all one brand?
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Not a problem whatsoever.
  3. Bob_M
    Bob_M Stunt Coordinator
    Apr 3, 2000
    194
    >Probably a stupid question, but can I safely mix different brands of connection wires?<
    Just curious, why not get it all from Blue Jean?
  4. Ken Chui
    Ken Chui Supporting Actor
    Jun 20, 2003
    976
    I was wondering the same thing as well. Not to take away anything from BetterCables (as they're highly regarded), but BJC does offer an RCA cable for substantially less.
    Some of us are sticklers for brand uniformity, but pursuing this can be a costly venture. I mix 'n match my cables and am satisfied with my results.
  5. Todd smith
    Apr 2, 2002
    643
    As far as video goes, as long as I have really good component cables I will be satisfied (not really a videophile). In this case the BJ's seem great for me. However, for audio I want the best I can afford. Is there a better rca cable for the money than the better cables? I actually need 13 cables (6 pair+1single) for my dvd-A/sacd hookup and to hook my amp to my pre/pro. I am under the impression that cables do make a difference, but am I getting suckered on the bettercables or are they worth the money? Have not bought anything yet so I am still open to suggestions.
  6. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    its unlikely you will tell much difference at all.
  7. Robert_Dufresne
    Robert_Dufresne Stunt Coordinator
    Mar 30, 2002
    246
    Yes Todd you are being suckered into spending more money than you have to. Like Mike said,
  8. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Cables do have a small influence on the sound similar to the way the glass makes a difference in the experience of drinking wine.
    It would be very hard to quantify if a $18 wine glass gives a better experience than a $24 wine glass. In this same fashion, it's hard to judge if the BetterCables product changes the experience better/worse than the BlueJeans product.
    Both products are very good and compared to some retail brands - a great value. Both companies have a good reputation around here for standing behind their product and both (last time I looked) have a good return policy.
    But it's a Coke vs Pepsi type of recommendation you are asking for.
    I have a suggestion for you:
    Order 1 pair of audio cables from each company. Spend a happy afternoon with 1 speaker going back and forth. (Sounds silly - not really. A single sound source will remove a lot of variables involved with a multi-channel system). My guess is you will make a decision based on appearance/build quality as much as anything else. (In listening tests where the audience got to see the cables, the thicker one almost always sounds better.) Make your "coke vs pepsi" decision with a sample of each. Then return one and order the other 6 cables from the vendor you prefer.
    This way - you get the best cable for Your system, your music, your taste. It really is the best way to decide.
  9. Todd smith
    Apr 2, 2002
    643
    Thanks all. I like the idea of trying out one of each as this will satisfy my curiosity and then order the rest of the cable I liked best. Thanks again.
