Is it ok to Biamp front Speakers with another RECEIVER???
Discussion in 'Archived Threads 2001-2004' started by EricTang, Feb 12, 2003.
  1. EricTang
    EricTang Agent
    Jan 22, 2003
    25
    Hi, I am just wondering what happens if you Biamp the front speakers with 2 Different RECEIVERS (not separate amps). Something like this: Receiver#1: Speaker set A (both front L/R speakers) connects to the top binding posts of front speaker L/R with speaker wires. Receiver #1 again: From Speaker set B (both L/R)PREOUT to Receiver #2, then connect the bottom binding posts of the L/F front speakers to Receiver #2.
    I dont know would something like this work?? Any advise before I do this with my old receiver??
  2. Brian Fellmeth
    Jul 30, 2000
    789
    Sounds like a bad idea to me
  3. JeremyFr
    JeremyFr Supporting Actor
    Jan 28, 2003
    794
    I wouldn't recommend it either.
  4. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,412
    312
    9,110
    Cees Alons
    Don't do it!
    You're effectively "bridging" two amplifiers, but because they are not equal (and may carry different signals), the results could be disatrous. To your sound, to your amps and even to your speakers.
    Cees
  5. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    It'll work, but it's a bad idea for a few reasons. First, different models of receivers will not respond identically to a rising volume, so it's likely that your woofer/tweeter output will not be in balance. If you leave the 2nd receiver's volume control at, say, 75%, your signal-to-noise ratio will rise as your volume drops. Depending on the receiver, this might be very audible at low volume. Also, using the bi-wire posts often bypasses the internal crossover and you're not compensating for this, so you might be asking your woofer to tweet and your tweeter to woof! Your speakers won't last long this way!
  6. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    You can do it, but not the way you said here:
