Joel Walker
- Apr 30, 2002
Speaking hypothetically, if one had the means to purchase independent amplification for each channel, or at least a seperate multi-channel amplifier for the rears, which of these approaches should yield the better final result? :
a) doing the bulk of a longer run (say 15-25+ feet) from the source & pre processor to the speakers with a low level signal, and positioning the amplification close to each speaker itself, or
b) amplifying close to the signal source, and doing the longer portion of the run with speaker cabling.
I suppose there is also option c), at least in principle, which would be superior to both (and increasingly costly, assuming technology even permits) -- send a post processed digital signal on something like optical fiber to the physical location of each speaker, where it is converted D/A on site and then powered.
any thoughts?
any thoughts?
