Is it bad to put subwoofers right next to your TV?
Discussion in 'Archived Threads 2001-2004' started by BrianFS, Apr 14, 2002.
  1. BrianFS
    BrianFS Auditioning
    Apr 7, 2002
    9
    Because that's exactly what I'm doing. I was wondering if it's bad for the sub and/or TV. My subwoofer is not magnetically shielded but I've experience no sound distortion from the sub nor picture distortion from the TV.
    Here's my setup.
  2. GaryAR
    GaryAR Agent
    Apr 8, 2002
    45
    i would definately not reccommend that setup.
    first of all, the sub is definately too close to the tv. even if you don't see distortion on the screen, it can't be a good idea.
    second, your sub should not be sitting on a dresser, it should be on the floor.
    third, your fronts are not located symmetrically. i'd suggest that you put the right speaker on a stand, at the same height as the left and the same distance from the center of the tv.
    -gary
  3. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Right, as Gary mentioned...the performance from a subwoofer is largely dependent on optimizing its position in the room. Corners tend to work well for subs...preferably a corner near the key seating positions. Also, be sure to calibrate the entire system using a SPL meter($35 from radio shack).
    TV
  4. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    Yeah, at least put that thing on the floor! You will notice it will sound a lot better too! Also putting it on the floor will give you more freedom in placing your main speakers optimally.
  5. Mark Larson
    Mark Larson Supporting Actor
    Mar 3, 2002
    537
    Eish!! [​IMG]
    You definitely need to do a lot of changes... Start with these...
    1. Put the sub on the floor, but quite close to your seat position. It looks like a weak sub, so it would work.
    2. Pull out the L-R speakers a bit forward.
    3. Put the center at the same level as the two speakers you just "pulled out".
    My goodness, that's a really bad setup! You'll be glad you asked us!
    Do you have 5.1?
  6. Mark Larson
    Mar 3, 2002
    537
