Is flat screen worth it?
Discussion in 'Archived Threads 2001-2004' started by Ten_Smith, Feb 5, 2002.
  1. Ten_Smith
    Ten_Smith Stunt Coordinator
    Dec 21, 2001
    76
    I was planning on buying the Toshiba 27AF41, but have seen some reviews complaining of geometry problems. Similar complaints about the Sony Flat Screen.
    If I get Avia, go in and make adjustments which set will end up with the better picture?
    Is flatscreen even worth it?
    I need to stay at the 27" size, which should I get, or should I get something else?
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    By its very curved nature, a conventional picture tube introduces a bowing distortion to all that you see. Not so with a flat screen. Though the electron beam has more of a challenge from within a flat screen, the overall picture makes it worth it. Flat = cinematic.
  3. Jacob_St
    Jacob_St Second Unit
    Jan 15, 2000
    259
    I have a flat screen and I can honestly say I'll never go back to the traditional curved screen. I say try it out. Usually a department store gives you 2-4 weeks to bring the set back if you aren't satisfied.
  4. Ten_Smith
    Dec 21, 2001
    76
    Thank you gentlemen. I think I was suffering from pre-buyers remorse. Hopefully I can just get that out of the way up front and enjoy the set when I bring it home.
