is constantly adjusting convergency hurting my HDTV?
Discussion in 'Archived Threads 2001-2004' started by ethan_l, Jan 8, 2003.
  1. ethan_l
    ethan_l Stunt Coordinator
    Oct 25, 2002
    72
    I frequently use the auto focus/manual ajustment on my TV to
    get the right alignment
    but recently I noticed that when I first switch on my set
    the picture is sometimes shift up about 1.5mm leaving a very
    thin blank edge on the bottom or sometimes the bottom and
    top edge are curved in slightly so if you look closely at
    a straight edge across the top of screen, you notice that
    the line curves down slightly towards the center
    also yesterday I noticed that the whole screen is very slightly tilted to the right side
    I have been able to fix this problems by doing a couple of auto focus. 'cept for the tilt problem, it did go away
    just wondering if anyone else had this experience with their set
  2. ethan_l
    Oct 25, 2002
    72
    come'on some help here guys
  3. Dave H
    Dave H Producer
    Aug 13, 2000
    5,555
    186
    9,110
    Unless you have a problem, under normal circumstances I don't see how it would hurt. On my Sony RPTV, the convergence is saved and programmed in the system. So, every time I hit the convergence button, it is just realigning how it was initially set.
    I use the convergence button usually twice a week and everything seems fine.
  4. Inspector Hammer!
    Inspector Hammer! Executive Producer
    Mar 15, 1999
    11,061
    Houston, Texas
    John Williamson
    Did you account for drifting due to the set being off for an extended period? I know that when I first turn my HDTV on after it being off over night, my convergence as well as my pictures bright level is off to a degree.
    However after it has been on for about an hour or less the picture falls back into it's normal appearance that I calibrated it.
    Sometimes it just needs to warm up.
