Is anamorphic "A Bug's Life" worth a double dip?
Discussion in 'DVD' started by ChadM, Aug 10, 2004.
  1. ChadM
    ChadM Stunt Coordinator
    Jun 5, 2000
    234
    Just wondering.
  2. Craig S
    Craig S Producer
    Mar 4, 2000
    5,727
    199
    League City, Texas
    Craig Seanor
    ??? The previously-released widescreen versions of A Bug's Life have always been anamorphic.
  3. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    Incorrect. The initial release was letterboxed, but not anamorphic.
  4. Marc Colella
    Marc Colella Cinematographer
    Jun 19, 1999
    2,601
    I thought all versions of A Bug's Life was anamorphic except for the P&S release.
  5. Arnie G
    Arnie G Supporting Actor
    May 29, 2002
    662
    The first release was non-anamorphic. Do you have a TV that takes advantage of anamorphic dvds?
  6. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    That's correct. The first DVD was non-anamorphic. The 2 disc CE (which is out of print I believe) and the newest version (released around the time Finding Nemo came out) are anamorphic. The second anamorphic release is also THX ceritified, while the others are not.
  7. ChadM
    Jun 5, 2000
    234
    Yes the TV is HiDef Wide and the version of A Bugs Life I have is most definitely not anamorphic.
    Let me explain the question further - with several titles coming out in enhanced mode (goodfellas, rounders, etc) that were previously letterboxed I am starting to think about weeding out some of the letterboxed titles in my collection. I was thinking a bugs life would be a good test case.
  8. John Sparks
    John Sparks Screenwriter
    Sep 12, 2001
    1,308
    243
    Menifee, CA
    John Sparks
    That's what I did and sold around 65-70. Slowly I am replacing them, such as "The Thing"; "Christine S.E."; "Candyman S.E."; "Videodrome S.E." etc. [​IMG]
  9. Craig S
    Craig S Producer
    Mar 4, 2000
    5,727
    199
    League City, Texas
    Craig Seanor
    Ah, OK, I bought the 2 disc SE several years ago, and completely forgot there was a non-anamorphic version before that.
    To answer the question then... YES!!!!
  10. Elias A.
    Elias A. Stunt Coordinator
    Jul 1, 2003
    72
    It's absolutely worth it to upgrade. The anamorphic version has some of the best picture quality I've ever seen. I've heard that the non-anamorphic version is pretty good, but why not go for the extra 33% resolution?
  11. Tim Glover
    Tim Glover Lead Actor
    Jan 12, 1999
    8,050
    327
    Monroe, LA
    Tim Glover
    Agreed. Excellent presentation. And a great film to boot.
  12. Dan Rudolph
    Dan Rudolph Producer
    Dec 30, 2002
    4,042
    The 2-disc CE is in print and can easily be obtained for $20 in many places. I'd advise getting it.
  13. Stephen_J_H
    Stephen_J_H All Things Film Junkie
    Jul 30, 2003
    5,532
    841
    North of the 49th
    Stephen J. Hill
    The 2-disc CE was reissued (with a few Finding Nemo extras)and and is one of the few times I have double-dipped on a title. The anamorphic transfer is a real sparkler.
  14. Ken_McAlinden
    Ken_McAlinden Producer
    Feb 20, 2001
    6,190
    76
    Livonia, MI USA
    Kenneth McAlinden
    All of the transfers (non-anamorphic 2.35:1, recomposed 4:3, anamorphic 2.35:1) released of A Bug's Life have been excellent. If you are interested in the very well-produced extras or are disatisfied with the vertical resolution of the disc you have, it is worth an upgrade, otherwise, you have all you need. The transfers are otherwise identical and there is no significant improvement in the compression. All versions released include the recomposed 4:3 version on the same disc as one of the OAR versions, so you can't avoid it if your try. [​IMG]
  15. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    The 16x9 version is absolutely 100% worth the upgrade. In fact, it's one of the best A:A comparisons...exactly the same digital source...one downconverted from HD to 4x3 lbx, one to 16x9 lbx...so you're really seeing an apples to apples demonstration of just what improvement you get with 16x9 encoding on a 16x9 capable display. And it's good [​IMG]
    One of the "reference" transfers out there. Somehow managed to escape most of the EE we see on Disney DVDs today.
    -dave
  16. John Alderson
    John Alderson Supporting Actor
    Aug 8, 2001
    562
    Slightly off topic for this thread... but what are people's feelings towards the "recomposed" 4:3 version? I watched it once (I still have just the original release), and I honestly thought it worked ok. It felt more made for TV (or pre-1953), and not really in a bad way. I think they did a pretty good job of it.
    I still prefer the widescreen version, but this was an interesting idea for a CGI film. I'm also not eager to see this feat repeated -- 2.35 is a very satisfying (and underused) AR for animation. But I thought it was a fascinating experiment. Have any other CGI films taken this route?
  17. Jim Barg
    Jim Barg Second Unit
    Apr 7, 2004
    395
    Jim Barg
    Hm. Parts of Titan AE were CG, but that's the only sort-of example I have. I'd bet that The Incredibles will be 2.35:1, though.
  18. jason:g
    jason:g Stunt Coordinator
    Apr 16, 2004
    242
    Yeah, the recomposed 4:3 version also works great. But one prefers widescreen for the cinema effect.
  19. ChadM
    Jun 5, 2000
    234
    Ok based on the recommendations here I got it and I have to say I am impressed.
    Much better looking film now. The extra resolution really helps. Makes it less "jagged". I don't know if that is the right word.
    David, funny you said that the transfer escapes "most" of the EE that tends to plague Disney films, because that was one flaw I noted, albeit it a minor one.
    Thanks for the help, now I am going to determine which DVD's I may need to replace. Luckily I was pretty good about holding off on non-anamorphic DVD's early in building my collection.
  20. Enrique B Chamorro
    Enrique B Chamorro Supporting Actor
    Sep 2, 1999
    514
    What does the cover of the old version look like?
    I may find it and rent it and then do a side by side
    comparison.
