Is an Xbox too heavy to place on top of a DVD Player?
Discussion in 'Playback Devices' started by Scott Burke, Jan 2, 2004.
  1. Scott Burke
    Scott Burke Second Unit
    Nov 27, 2000
    479
    31
    United States
    Scott B.
    When I read the owners manual for my sony DVD player it said not to put anything too heavy on top of the player. What is too heavy? I put my Xbox on top of my previous player and it did not bother it, but I'm curious if it might do something I'm not aware of. Thanks.
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    If it's a Sony then anything goes :wink: but seriously you should be fine, especially if the Xbox's feet are close to the edges of the frame rather than right in the middle where the disc mechanism is.
  3. Scott Burke
    Nov 27, 2000
    479
    31
    United States
    Scott B.
    Well, it is a five disc changer. As long as I have it close to the front is should be fine? thanks again.
  4. Jeff W.
    Jeff W. Stunt Coordinator
    Dec 21, 2003
    141
  5. Oachalon
    Oachalon Stunt Coordinator
    Apr 23, 2002
    195
    ive had my xbox on my panasonic rp-82 for about a year and it has done no harm to it. It will be fine.
  6. Jason_A
    Jason_A Stunt Coordinator
    Jun 25, 2001
    94
    I wouldn't its extremely heavy.
  7. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    It depends on how strong the top of your player is. The X-box is significantly narrower than most HT components. This means it will be resting all of its weight on the unsupported portion of the top, unless there is a middle support which I doubt. Push on the top of your player and see if it flexes any. If there is too much give, then putting the xbox on it could cause the center to bend down, which could eventually cause problems.
  8. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    I would say you're okay - that's like 10 pounds at most. It's not like you're stacking an amp on it or something like that.
  9. Jonathan Dagmar
    Jonathan Dagmar Supporting Actor
    Dec 29, 2002
    723
    I have my panasonic xr25 reciever on top of my dvd players, and it weighs about the same as the Xbox. I would rather have it on it's own shelf, but sadly space is not on my side.
    The reason the reciever is on top of the dvd player, which is much lighter than the reciever, is because the reciever gets hot, and the dvd player doesn't, and I did not want to hinder the reciever abilty to dispate heat, nor transfer heat to the DVD player... Something to keep in mind when positioning all your equipment...
