Is a special cable used between receiver and Sub AMP?
Discussion in 'Archived Threads 2001-2004' started by Ernest R, Aug 10, 2002.
  1. Ernest R
    Ernest R Agent
    Jun 6, 2002
    28
    Is a special cable used between the receiver and a Sub AMP? I am looking for something to replace the a cheap RCA cable? Any suggestions?
  2. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    a good RCA cable!
  3. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    The sub connection is one of the least important line level connections IMO. The bandwidth is only 10% of the other channels, distortion is usually higher and SNR usually lower, so there's not much point in using a premium cable for it. Just get a normal, decent coaxial cable with decent RCA connectors.
  4. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    Just use a good sheilded RCA cable. I use a Monster sub cable (M350i) without incident.
  5. Luis C
    Luis C Stunt Coordinator
    Mar 17, 2002
    192
    Check out the Better Cables pieces... they have worked incredibly well in my system...
  6. John A. Casler
    John A. Casler Second Unit
    Apr 29, 1999
    475
    Use a "high quality" shielded VIDEO (75 ohm) cable. A specific sub cable is best, but a regular audio cable (while it will work) is the wrong impedence.
    John Casler
  7. Eric T
    Eric T Second Unit
    Apr 1, 2001
    266
