Mitch G
- Feb 3, 2004
The speaker set up for my Yamaha 5640 has a step where you indicate whether the Center, Mains, or Surrounds are considered "Large" or "Small." (This setting is made for each type of speaker individually, but I'm condensing them here.)
The difference as stated in the manual is as follows:
LRG: Select this if you have a large center/main/surround speaker. The unit directs the entire range of the center channel signal to the center speaker.
SML: Select this if you ahve a small center/main/surround speaker. The unit directs the low-frequency signals (90Hz and below) fo the center channel to the speakers selected with "1E BASS."
(1E BASS is then set to "SUBWOOFER" or "BOTH." BOTH indicates the low frequency stuff goes to SUB and the center/main/surround depending on what their "LRG" or "SML" setting is.)
I'm guessing that the small setting is for satellite speakers whereas my Atoms (which I'm using for mains and surrounds) and my CC-170 center are actually considered as large in this case? But, then I started wondering if large actually applied to towers or similarly large speakers with sizeable woofers.
So, does anyone know?
Are Atoms large or small in this case?
And, is a CC-170 large or small?
Mitch
Mitch
