I've heard the 360 can use a VGA output. If so, can it be hooked to a VGA monitor (.2mm dot pitch, 1280x1024 res) and how would the image compare to an SD television?
I'm asking because I'm leary of hooking to my 40" Toshiba HD set. I've never run a console on my set and wish to avoid burn in, but I also want a better picture than the 25" SD tv to which my PS2 and Gamecube are hooked.
As for hooking any gaming system up to a projection television, as long as you have your set adjusted using Avia or Video esentials you should have no problem. I've had consoles hooked up to my projection tv for 6 years now and have no burn-in at all.
