Is 92 decibels (signal to noise ratio) low for a CD player ?
Discussion in 'Archived Threads 2001-2004' started by anthony_b, Sep 22, 2001.
  1. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,077
    4
    110
    This is one of the specs for the new Onkyo cd changer model 380. Should I look for something a bit higher ?
  2. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Geoff
    Are you sure you read it correctly?
    s/n 92db
    If so, this seems low to me for the Onkyo.. I would expect to see a 100 or better.
    Anyone else have input on this?
  3. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    I found it wierd myself. I got it from the crurchfield site.
  4. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    Slight mistake...It's actually 96 decibals, still kind of low even compared to the low end sony changers !
  5. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    Onkyo's site saids 96db, and Crutcfield's saids 92db ?
  6. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Yes, I think it's pretty low. My 3 year old Parasound CD changer has a 110dB signal to noise ratio.
  7. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    Would there be a big audible differance ?
  8. Tony Genovese
    Tony Genovese Supporting Actor
    Oct 5, 2000
    811
    No!
  9. Steven Lin
    Steven Lin Extra
    Aug 25, 2001
    22
    Why does 96 dB sound low? 96 dB is the theoretical S/N ratio of a 16-bit digital audio format.
  10. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
  11. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    I tend to disagree that the music won't be affected by the S/N ratio. The lower the noise threshold, the more musical detail, even low level detail, gets through.
    I've been able to hear more detail from very familiar music with the increased S/N ratio of my current CD player. This means I can hear fundamemtal notes from various instruments that I could not hear before. The CD player was the only item changed in the system, and the SPL at the listening position registered exactly the same numbers as before.
    IMHO with my system and music.
    [Edited last by BruceD on September 23, 2001 at 01:42 PM]
    [Edited last by BruceD on September 23, 2001 at 01:44 PM]
  12. anthony_b
    Aug 18, 2000
    1,077
    4
    110
    From what I understand, the higher the s/n ratio number is, the cleaner the sound. I'm still puzzled by Onkyo. After downloading the manual from there web site it saids that it's 92db (the signal to noise ratio). I might go with the sony ES model instead (70es changer).
