Is 7.1 worth it in a small environment? (1 Viewer)
Jeff Brink
Being new to HT, I am trying to evaluate whether or not to spend the xtra money on rear effects speakers. Purchased the Denon 3802 and PSB 4T's, 8C, and 10S's. Purchasing in the next couple of weeks my SVS 20-39 sub. My room is almost square - 15'x17'. Currently, I have my 10S's slotted to be placed on the side walls almost directly above the main listening area. I have a back wall that would be ideal for two 1B's. How much added sound can I expect from them in this type of setup. The 10S's are dipole and did an excellent job of filling the listening area when I listened to them at the store. Unfortunately, the store did not have 1B's in stock to add to the equation. For the extra $200, will I get my moneys worth out of them since there really aren't too many applications for 6.1 let alone 7.1 at this time? Thanks for the help!
peter_anderson
i would suggest waiting until you
1. are thoroughly bored with your current setup
2. have a larger room
oh, and there aren't that many DTS-ES titles anyway
Michael Reuben
Michael Reuben
It's not a question that anyone can answer. What may be worth $200 to some may not be worth it to you.
The real problem here is that you're asking about something ("7.1") that doesn't really exist. For a detailed discussion, please refer to this thread in the Receivers/Separates/Amps forum.
The short answer is that a 7-speaker setup can work very nicely in the space you have to work with, IF the processor driving it is the right one. I have a space that's not much bigger, and Lexicon's Logic7 offers a noticeable improvement over basic 5.1. But I doubt the Denon would sound nearly as good, because it just doesn't have the sophisticated 7-speaker processing that is Lexicon's specialty.
M.
Demoniac
