Miles
- Jun 30, 1997
I feel like newbie here... I guess I am in the end...
I have a Marantz 6300 which only has amplification for a single rear channel. I have a single Paradigm Titan hooked up right now. I'm not happy with the soundfield I'm getting and thinking I need two speakers to ensure my brain perceives the sound as coming from behind me. Somewhere I read if the single channel is directly behind your head, your brain/ears may not be able to tell if the sound is coming from behind you or in front of you...
Which leads me to the question, could I hook up two Titans to the same amplified channel? If it works (and is relatively safe), I'm guessing it would provide me with a better sound field... Or, would I have to split the mono signal and run it through a two-channel amp to power both Titans?
Thanks for any help,
