TomK
- Mar 17, 1999
As always, if you need expert advice, ask you guys.
OK, so I have an IR input on the back of my A/V Receiver. Normally you would plug an IR blaster into it. However, I want to computer control my system and my thought was to use a SmartLinc or similar product. I use HomeSeer to automate my lighting (great product by the way) and HomeSeer can control the SmartLinc. My A/V Receiver has an IR "In" on the back but I'm not sure if I can plug in a cable from the SmartLinc to the A/V Receiver? Does this work this way or do I have to use a stick on emitter?
Thanks!
Thanks!
