And...it's gone. iPhone 13 no longer listed in my Cloud Tabs...subsequent to 15.0.1 update?A week later, my new iPhone finally shows up in Safari’s iCloud Tabs. Whew! I use that all the time!
Now waiting for my purged and deleted iPhone 8+ to get removed from iCloud Tabs!
Actually, the latest version of macOS is Big Sur, soon to be replaced by Monterey. You're currently running the latest and greatest macOS that supports your 2011 iMac. You can't move to a more recent version of the operating system without getting new hardware.
macOS Big Sur is compatible with these computers - Apple Support
You can install macOS Big Sur on any of these Mac models.support.apple.com
So I have a an iMac Which I purchased from Best Buy when I lived in Tampa in 2011 Its so old it still has a built in Physical media drive. I am typing this post on it as we speak. I just noticed it running Sierra but that the most up to date Mac os Version is Catalina .. I Went to updates and it says I have none. Am I correct in assuming Apple is No longer supporting my 10 year old Computer? I would hate to have to buy a new I mac. I have never had a problem with this one
Settings App -> SafariAre there setting for Safari on iPad?
I swear right after I added iOS 15 and opened Safari I could see the the tabs on the bottom now I don’t and don’t see any settings to change it back to bottom.
Also I thought there was an option for floating tabs on screen?
I use Chrome about 98% of the time but I wanted to see what was going on with Safari.
I found and tried the Apple Support process.And...it's gone. iPhone 13 no longer listed in my Cloud Tabs...subsequent to 15.0.1 update?
I wish iCloud wasn't completely opaque. I want some error codes and debugging features and "refresh" buttons to mash!
So, I did it again, but skipping the restart step.I found and tried the Apple Support process.
If your iCloud or Safari bookmarks aren’t syncing
Learn what to do if you have issues using iCloud Bookmarks or Reading List. For example, if you need to access a bookmark that you accidentally deleted or make changes in your web browser that don’t update on your other devices, we can help.support.apple.com
My iPhone 13 appeared in my iPad’s iClod Tabs for literally about a minute afterwards, and then vanished again.
I’ve got to find time to call Apple. Something’s wrong. (I’m ready to reset my iPhone and reinstall, hoping that will fix it. But I don’t know the best way to do that without nuking my cell plan.)
