"Invisible" flat wall speaker wire
Discussion in 'Archived Threads 2001-2004' started by Radim, Sep 7, 2002.
  1. Radim
    Radim Extra
    Aug 11, 2002
    18
    Is there any consensus opinion on flat "invisible" speaker wire that goes on a wall? I just saw a the AR brand of it in a local store and it seems like a great solution for my wall-attached rear JBL N-24 speakers. However, I do not want to sacrifice much sound quality. Will that be the case and should I stick with regular 12 gauge cable instead? Or are there any other good alternatives for wall placement? Thanks for any opinions/advice.
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    no you won't sacrifice anything in sound quality. there are a few places you can get something like that
    www.partsexpress.com
    www.decorp.com/
    the last one is a new one for me and i haven't checked out their prices. one could, if they want, run 12 gauge and then splice into it if they want to avoid some expense.
  3. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    for surround speaker use any half decent 12awg speaker cable will do.
