Rob Speicher
- Nov 24, 2000
Anyone with OOL will beat it by a longshot. Lucky bastards
Your raw speed was 3016530.74 bits per second3 mbps, not too bad. i'm on adelphia cable modem, southeastern mass.
CJ
Hmmmmmm.....i got the same thing, a very high number, on my second try. i think its because you hit the back button instead of 'retry the test'. when you hit the back button, the file they have you download for the test is still in your cache, hence the huge speed. at least thats what i think is going on. i got 35 mbps on my second try like that.
CJ
How did you get a 4.4 Mbps on a T1, given that T1 has a maximum throughput of 1.5 Mbps, and even that is almost never 100% full at all, much less saturated from a single source?Um ... you can't. Perhaps T3 was meant to be typed instead?
Actually, the problem is that these tests are not very accurate, no matter how many times you run them. This whole thing is sort of like Vascar - we'll start the clock, send you some information, then stop the clock and just assume that we have accurate results based on a miniscule amount of data. You can't possibly determine an accurate result based on a quick packet transmission from a web site.
The best thing to do is to try to locate a server that is internal to your ISP and download a several-meg file, preferably more than 25 MB if possible. That not only gives you a better potential bandwidth reading, but the size of the file means that you can get a better reading of total throughput since the client will have more samplings/readings with which to average the true data transfer rate.
A T-1 greater than 1.5? Um, no. I don't think so.
