Lee Scoggins
This is a good article on Break-in of audio components I thought people would enjoy...
http://www.ultraaudio.com/opinion/20030801.htm
Why is break-in always a positive thing? If something changes with use, what is preventing it from being percieved as negative?Break-in to me isn't always a positive thing. Positive/negative in a subjective view that is.
But generally before I listen to a product(with intent on purchase) at a dealer, I check to see how long that product has been used. If its directly out of the box or barely used, I come back another time.
TN and his kind aside.I'd like to be his "kind."
Two more thoughts. One is that I work for a semiconductor company. We make AD and DA converters, DPS chips, op amps, microcontrollers, and a whole bunch of other stuff you've probably never even heard of. We live or die by "yield" and the quality of the parts we make. If there was *any way* we could either improve yield, or improve parametric electrical test performance by "breaking in" our devices, chips, and boards, we'd do it. But it just doesn't happen.
Two is that, yeah, I read the Audio Critic article, and even though I do personally believe that break in doesn't exist for electronics, I still have my doubts about speakers. Simple example is that I just replaced 7 of the 7.1 in my system. As soon as I got everything hooked up, I balanced levels. 4 weeks later after a lot of CDs and DVDs and FM, I finally got around to balancing that analog output from my player. I went back and did the levels in my pre/pro. The levels in my pre/pro were different from when I had originally set them. FWIW.
