Interconnect - Video cable OK?
Discussion in 'Archived Threads 2001-2004' started by Martin Jiang, Jan 23, 2003.
  1. Martin Jiang
    Martin Jiang Agent
    Jul 13, 2000
    31
    I am in need of some interconnect and bought some acoustic research. By mistake I used one of the video cable for the center channel preout and did not notice any difference. Is there any reason not to use video rca cable for interconnect?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    It should work fine, but I'd expect a bit of a volume reduction on the center speaker compared to the L/R.
    Audio cables are typically made with something called 50 ohm coax. But you can use 75/110/300 ohm coax. At one time, some bundled cables of Left/Right/Video were all made with 75 ohm coax.
    Video cables MUST be made with 75 ohm coax. Thats the convention.
    Just use a sound meter to make sure the center is level-adjusted to the R/L.
  3. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    As far as I know, there is a slight difference in the resistance of the video cable (75 ohms) versus 50 ohms for the audio sides. I don't hesitate to use the video cable for audio. I would venture to say that using the video cable for audio should be below the lowest audible difference.
    Perhaps some of the EEs can be more detailed and specific.
    Artie
  4. Jonathan_D
    Jonathan_D Stunt Coordinator
    Jan 22, 2003
    142
    Lengthy discussion on another board about this. Unless the cable runs are fairly long (say above 25') the loss occurring in a 50ohm vs. 75ohm cable is neglible for the composite video. I've got a plain old audio cable for one of my hookups (as well as the "coaxial" digital) and it works fine.
    If you didn't notice a problem, don't create one! [​IMG]
