Interconnect cables: Amp or source more important?
Discussion in 'Archived Threads 2001-2004' started by James Elvick, Mar 26, 2002.
  1. James Elvick
    James Elvick Supporting Actor
    Jan 12, 1999
    690
    I just received a pair of Silver Serpent cables to try out and not sure what would be the most advantageous: between the prepro and amp or prepro and the cd? Equipment right now is as follows:
    Denon 3802 as preamp
    Parasound 2205
    Denon DCM370
    Paradigm Studio 40's (Rosenut Veneer[​IMG])
    SVS 20-39+
    Whadda ya think!
  2. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
    James,
    Are you using the analog outputs of your CD player or digital?
    If digital, then I guess the answer would be easy. . . [​IMG]
    But if analog--hey--how about trying both positions and letting us know your impressions?
    Do you have any other sources (DVD, etc.) running into your 3802?
    Mike
  3. Jim A. Banville
    Jim A. Banville Supporting Actor
    Jun 20, 1999
    630
    Unfortunately, you probably won't hear a difference either way unless there was something seriously wrong with your previous cables. You do have the perfect opportunity to have a friend switch the cabes for you, without you knowing where or even IF the cables have been inserted, so you can determine if you can hear a difference without knowing [​IMG]
