integrating a tube amp???
Discussion in 'AV Receivers' started by Chris Trot, Jul 14, 2003.
  1. Chris Trot
    Chris Trot Stunt Coordinator
    Jan 4, 2002
    81
    I have an Outlaw 1050 and while I am happy with its performance, I wanted to integrate tube amplifier into my setup. Do I need a separate amp, can I get a preamp, I really have no idea what to do. I was thinking about getting the norh SE 9, but as I said I have no idea. I'm looking to spend $500 or less. I also am using Ascend CBM-170's and a Rava sub if that helps. Thanks for any help.
    Chris
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    I assume you’re interested in the tube for music listening? If so, piece of cake - as long as the Outlaw has pre-amp outputs for the left and right mains. No pre-amop needed if that's the case. Just send the signal from those jacks to the tube amp, them connect the L/R speakers to the amp. You will probably need to re-calibrate all the speaker levels.
    Wayne A. Pflughaupt
  3. Chris Trot
    Jan 4, 2002
    81
    It does, any suggestions for what amps to get. What about the Antique Sound Labs mono amps, any comments?
