Jim517
I need to move my antenna to the side of my house, and mount it in the ground. My plan is to set a 4x4 post in concrete(in a plastic "post protector" sleeve), then secure the pole to side of the 4x4. Then secure the pole to my fascia with a standoff bracket.
The coaxial cable will run thru a 90 degree elbow, then underground thru a PVC conduit, about 3' from the pole to the house, then enter concrete block wall in a coaxial thru wall bushing.
1) Since I can only hit one structural member behind the fascia board when securing the standoff bracket, what type of anchor is best for the other hole ? A toggle bolt ?
2) Is it best to keep the point of entry of the coaxial cable, into my house above ground level ? I will be using one of those small plastic coaxial thru wall bushings.
Do you see any problems with my plan ?
Thanks.
Thanks.
