Installing RAM in my notebook (1 Viewer)
Richard Kim
My Toshiba notebook had 128 MB of RAM and I decided to upgrade it to 256 MB. After I installed it and checked my System properties, it says I have 248 MB of RAM. What happened?
Richard Kim
Tekara
Your laptop may be sharing the system ram with the video card. Check the total ram in the Bios and see if the correct total is being displayed there.
Tekara
Tekara
oh... and there's always the thought that you may have bought a stick of ram rated in the decimal system and not the binary system.
That is, your stick of ram has 256,000 (256*10^3)bytes instead of 262,144 (256*2^10)bytes.
Tekara
NickSo
Nick So
Probably your video card in the lappy shares the ram with the system memory, and the video card uses 8 megs of ram (256 - 248).
NickSo
Nick So
spirittoo
