GrahamTAK
Grip
- Apr 14, 2004
Hi All!
I plan to install a projector in my new place which is under construction. So this is my first of many posts!
My plan is to run cable across the ceiling from the projector, down thru a drywall wall, along this wall, around a corner, through some more drywall, where it will eventually pop out and connect with:
- dvd player
- tv tuner / vcr
- xbox
- possibly my pc.
i.e.
./----Projector
|-----DVD (Screen)
I've been going thru a lot of these posts, and many have been helpful. ("Component Video Connectors" and "What Cables and support for a Front Projector?" especially.)
But I have two groups of questions:
1) CABLES:
A - how much ($USD) should it 45' of component, vga, s-video cost?
B - how much would a contractor bill me to install it?
C - would these be sufficient for DVD, XBOX, CATV, and PC?
2) CONNECTIONS:
A - Cant I just send a component cable up to the projector and have all the other units feed into some other central unit?
B - What would this be (an AV receiver, switcher, tuner?)
C - Can you recommend a no-fuss cheap one that you don't need a degree in astrophysics to use?
D - Do these do anything to the input signal along the way, like switch the resolution?
3) CONTRACTORS:
A - Finally, going out on a limb here, do you know of any professionals in TORONTO Ontario, Canada (Soviet Canuckistan to some) that installs this cable?
Thanks!
Graham
- dvd player
- tv tuner / vcr
- xbox
- possibly my pc.
i.e.
./----Projector
|-----DVD (Screen)
1) CABLES:
2) CONNECTIONS:
3) CONTRACTORS:
Thanks!
Graham
