Jay H
Now that I figured I'm going to use R25 to insulated the second floor crawlspace floor and R19 to insulate the crawspace walls, I have a question about actual insulation.
It appears that long time ago, the cotton insulation batts installed on the floor was installed paper side down, with the insulation open to the crawlspace. The walls seem to be installed paper side out to the crawlspace.
My limited understanding, I would think that for the unheated crawlspace, the insulation batts on the floor should have the paper side up, towards the crawlspace, which would sandwich the insulation material itself between the crawlspace floor and the paper (giving the airspace in between the insulation power). However, for some reason, the insulation I see on the floor has the paper side down and stapled to the ceiling rafters....
Shouldn't the paper side be facing up and into the unheated crawlspace??? Same with the walls on the second floor?
Jay
Jay
