Input level for BFD
Discussion in 'Speakers' started by Richard_M, Jan 17, 2004.
  1. Richard_M
    Richard_M Second Unit
    Feb 8, 2001
    265
    Does anyone know how important the input level is for the BFD.
    The reason I ask is that there has been a fair bit of discussion in the past that one should reduce the output of the Pre/Pro lfe channel to reduce distortion and raise the gain on the sub for calibration. If there is a BFD in the chain can this practice affect the performance of the BFD? I had also heard that the BFD may cause its own distortion thru lack of drive.
    Richard
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    You're correct, Richard. The BFD has to have an adequate input signal or else the A/D converters distort badly - that quantization thing with low-level signals. Worse case, the converters simply won't activate (for lack of a better word) at all.
    Wayne A. Pflughaupt
  3. Richard_M
    Feb 8, 2001
    265
    Thanks for the reply Wayne,
    My Denon LFE channel goes from +/- 15 (I think) and at the moment I am running it a -2, do you think I should up it into the plus side?
    Richard
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    You might want to check the "Setting Input Levels" section of the BFD Comprehensive Set-Up Guide.
    http://www.snapbug.ws/bfd.htm
    Wayne A. Pflughaupt
  5. Richard_M
    Feb 8, 2001
    265
    Thanks Wayne,
    Will set the levels this weekend
    Richard
