infocus IN76
Griff Hollywood
Keith
i am new here and looking to finish my theatre need a good projector..... i like the look of the infocus IN76 but how clear is it and does it play HDTV sat and HD DVD?
Jim Mcc
Oconomowoc, WI.
Jim
This projector has gotten great reviews, it is a native 720p(HD) DLP projector, and will display HD-DVD and HDTV. This is the projector I'm probably going to buy when the price comes down into my budget. It also has a small offset, which will work good with my low ceiling. Make sure it will work with your desired screen size and mounting location(throw distance). Also, if you buy an Infocus projector, you must buy from an authorized Infocus dealer or they will not honor the warranty. It says so right on their website.
conradfan
