InFocus 5700 or NEC HT1000?
Discussion in 'Displays' started by MarkSaxton, Aug 9, 2004.
  1. MarkSaxton
    MarkSaxton Auditioning
    Aug 9, 2004
    I have read what reviews I could find.
    The NEC has more pixels, the InFocus has a nicer back panel (multiple component inputs).
    I planned to run 2 component cables to my projector - one from the set top box and one from the dvd player. With the NEC, I don't think I'd be able to get 480p into the projector.
    Should I think about a component video mux / switch? Is there such a thing?
    I am leaning towards the InFocus because it is newer technology -
    * longer lamp life
    * better back panel discussed avbove
    * I will usually be watching DVD's in 16:9 and the extra pixels on the NEC only come into play in 4:3
    Still, the NEC will be more versatile on terms of projector placement (less ditance for a given image size, I don't know if that means higher or lower throw, but whatever) and that might come in handy someday.
    Anyone have either of these or have any reccomendations / opinions? My budget is 3200 or so.
  2. Sri
    Sri Agent
    Oct 3, 2002
    42
    I just purchased a Benq8700+ for few hundred more than your budget. Send me an email if you are interested to [email protected]. YOu will get lot more with 8700+ (hd2+ chip)
    good Luck!!
