YOU WILL LIKE IT A LOT.I HAVE ONE AND THINK IT IS THE GREATEST THING SINCE SLICED BREAD.JUST MAKE SURE WITH A SCREEN THAT BIG YOU ARE GOING TO BE SITTING 2X THE SCREEN WIDTH AWAY.THAT WILL BE ABOUT 15 FEET AWAY.
Do you have a link to a source which confirms this? I know the 7205 has a 48hz mode, but I've never seen anything which indicates the 4805 can do this.
hi all it came yesterday.i will be mounting it on the ceiling. my question is i will be using component cable and i need at least 40 feet of cable.will i loose any quality of video with such a long run.
I've been trying to use your modeline, but all my 4805 shows is 640x480 or 1024x768, could you send me you xorg.conf so I can check it out? If you want to you can mail it to [email protected] of course with the NOSPAM and underscores removed
