Info on 20 amp circuits
Discussion in 'Archived Threads 2001-2004' started by Ted Robinson, Nov 7, 2001.
  1. Ted Robinson
    Ted Robinson Extra
    Sep 13, 2000
    24
    Hi I am looking for a good website or book that will tell me about installing dedicated 20amp circuits in my home theater. I have never really done anything like this, so the simpler the better [​IMG]
    Thanks in advance,
    Ted
    Ted Robinson
  2. Tom Boucher
    Tom Boucher Second Unit
    Mar 1, 1999
    280
    I'm sure your local library has the time/life home repair book section. find the one on electrical stuff. Sure that's the best source.
    My DVD Collection
  3. Ron Hanson
    Ron Hanson Agent
    Jan 19, 1999
    40
    Well, it is pretty simple. Use 12gauge wire minimum, use a 20amp outlet, use a 20amp breaker.
    Ron Hanson
    Our dedicated theater page
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    If you strike out at the library, you can find any number of books on residential electric subjects at your local hardware store.
    Wayne A. Pflughaupt
    My Equipment List
  5. RossB
    RossB Extra
    Nov 8, 2001
    21
    Although you can use a dedicated 20 amp breaker for your entertainment system it is unlikely any single component will use 20 amps. Instead what you might consider is a couple of 15 amp breakers...each dedicated to a single outlet. To do this you need to make sure that you have sufficient room on your electrical panel. Purchase a tandem breaker (make sure you get the correct brand) and some 14/3 electrical wire. Normally you but 14/2 but 14/3 is good for two runs, and is less than two runs of 14/2.
    For my system I have 3-15 amp breakers each running a single plug which is sufficient for 6 components. For the amp and RPTV I have a single 15 amp breaker for each. To do this you can break the tab between the two plugs, and you have a dedicated breaker per. It is a bit of overkill but I have lots of room for expansion. You are thinking ... thats alot of breakers...which is true but I added a new panel for my home theater and computer so I have lots of room.
    There are manyreason why you want to do this .. but enough said
  6. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    However, if you ever go for a more powerful amp or series of mono block amps, they may indeed need one or two dedicated 20 amp circuits.
    The ATI 2505, Cinepro, Theta Dreadnaught and their new monoblocks, etc. all come to mind. They need da juice! [​IMG]
    Dan
    Stop HDCP and 5C-- Your rights are at risk!
  7. Sam C
    Sam C Stunt Coordinator
    Apr 30, 2000
    115
    Here's a link that will get you started without the fear of shocking yourself (Although I know someone who's an electrician who claims you're not a real electrician unless you get shocked once in awhile ... Then he'll go ahead and shock himself ... I never found him to be real bright)
    Anyhow ... Here you go ... http://www.howstuffworks.com/framed....iringpage.com/
    "I will drop-kick those f#$%ing dogs if they come near me."
    Frank T.J. Mackey ... Magnolia
