INFINITY Beta SW12 Subwoofer - Vrs. SVS (1 Viewer)
Mike_Cif
Wondering if anyone has ever had a chance to demo Infinitys Beta lineup of subwoofers, mainly the Infinity SW12. Looking on paper the power seems good, although perhaps not as deep in the freq department as SVS but not much is. One reason I bring up this debate is because the SVS is around $275 more, and obviously that is an amount that would make you consider another sub, even if its on paper for a bit. Would you say the SVS PB12 would be a much better purchase, or close call? I'm thinking since this is one of the higher infinity subs that are offered, Hopefully the built quality is good and up to it
Thanks!
Girish
Brecksville OH
girish
I have experience with Infinity IL120s subwoofer, which is basically same 12" CMMD WITH a 500 watt amp. I am more than satisfied with it. Excellent bass and very good build quality.
ScottCarr
Hi Mike,
Which SvS are you looking at?
PB12isd or
PB12+ or
PB12isd/2
Just trying to correlate the $275 you mentioned.
Scott
Vivacitythinks
